Maverick1701
- 206
- 63
- Lubbock, TX
Earlier today I ordered two new pinion seals off ebay for my front/rear differentials. I also ordered a set of those box end wrenches that ratchet and swivel (I also ordered two individual wrenches in sizes that I use on the jeep most that only ratchet and do not swivel). Almost every time I work on the Jeep I find a place where one of those would come in handy...so I finally pulled the trigger and ordered a set. Should be in soon.
When I got home today I removed the drive-shafts from both axles (left connected at the running gear end) in preparation for the new pinion seals. I am also trying to hunt down a torque wrench that reads high enough to set the pinion nut. Mine only goes up to 150ft lbs and everything I am reading calls for 160-180ft lbs.
I also started installing my new wheel cylinders. The wheel cylinders (at least the fronts) might get put on hold until I finish with the pinion seals and completely flush out my cooling system. I am still seeing some junk float around in the radiator.
