Got a Deuce! '62 M35A1
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
David, there is very little difference in the trucks not because of the bed or weight or tires, but the trucks axles and motor.
The trucks are severely limited because the motor puts out about 100hp and the axles have a 7:1 ratio. Its old tech that works great off road and minimally on road. It is what it is and I have accepted it.
On the topic of dot 3 vs dot 5, its ignorant to think there is a difference that anyone would ever notice.
DavidWymore
164
El Centro, CA
All the brake fluid talk and research made me decide to change the fluid in my '95 dodge the other day. I don't know if it has ever been changed. It was brown, but the brakes still work fine. Same thing with my '70 dodge. It's going to good use stripping civvy paint off the deuce.
gimpyrobb
27,786
755
Cincy Ohio
Investigating what? I have put a LDS motor in my truck and I have 395s on it. Thats about the best I can do other than going way custom. I still plan on putting a 5ton air filter on to help her breath better, but thats for later on.
DavidWymore
164
El Centro, CA
I will be running the truck in the desert. Some sand dunes and narrow canyons. I know smaller and lighter weight and a warm LDS 465 will help in the dunes. I may be new to deuces, but I am an experienced offroader/builder. Been doing nothing else in my free time for the last 15 years. I've run/built a Jeep, Blazer, and current big Cummins Dodge. They all perform differently and do better or worse in different terrain.
I know lightening the back end may be counterproductive. I was kicking around the idea of a gooseneck hitch that a bed could be latched onto when needed. I guess talking about it is pointless, it's alresdy basically an M48, will try it as such when the brakes are done and go from there.
DavidWymore
164
El Centro, CA
I was joking about the investigation due to your sig line.
I have also thought about cutting brakes (dual circuit) and or lockers...time to move to the other deuce forum I guess.
stb64
15
hohenfels germany
The military used regular brake fluid (called HB in the older lube orders) before switching over to DOT5. One of the reasons for using DOT5 was beeing able to keep huge amounts of vehicles in storage, often parked outside, without having to worry about regular brake fluid changes, only to find the brake cylinders all rusted when you needed the truck.
So using DOT3 is perfectly ok, as long as you do your brake maintenance.
DavidWymore
164
El Centro, CA
So far, pretty much all of the axles I have taken apart have had the grease washed out of the hubs by oil whether they had the little wedges or not. I think that's because the bearing and seal washer don't actually seal to the spindle.
Idea is to put a thin bead of gear oil specific RTV where the yellow paint lines are to seal the bearing and seal plate to the spindle.
DavidWymore
164
El Centro, CA
Yeah, there's a guy up in OR with a truck that looks like yours that has some vids on youtube, turned up and 395s, does good in the dunes. Course that sand might be damp, big difference to the dry sugar sand here.
Jeepsinker
456
Dry Creek, Louisiana
You don't need to put that much silicone when you pack the bearings. Just be sure to have the keyway clean and pack it up good with gear oil specific silicone before and after the seal install.
DavidWymore
164
El Centro, CA
Time to quit playing around with deuce #2 and get the brakes and wheels back on this one so its mobile and I can get it out of the bay it's hogging in the shop. It's getting embarrassing having it sit here this long.
I hate brakes.
rustystud
2,987
Woodinville, Washington
Do tell the tail please.
My buddy and his girl friend and I where in a 1 ton GMC dually towing back a 1952 Studebaker REO 6X6 I had bought down in Oregon. Coming back we went through "Glacier Lake" area to avoid traffic. Coming down off the plateau we lost the brakes in the dually and had to use the escape ramp which was thankfully there ! My friend was driving at the time and all I could do was hang on and pray we didn't end up going down the side of the mountain. Needless to say we all had the shakes after stopping !
This was my first deuce so I wasn't aware of how heavy they where. Also I was only 26 (still immortal) , a silly young kid who never thought about dying until then !
