Kaiser67M715
- 26
- 18
- NH
April is winding down, last week, so I pulled the girl out of hibernation, going through everything. Couple things I noticed, I'm a little low on brake fluid, but have yet to discover any leaks on the lines or at the wheel cylinders(still have 2 to look at) last place to check is my air pack, that is the only other place I can see losing fluid.(unless it was air between the reservoir and master, the pedal is still firm and the shoes I checked were dry of any liquid.
Second, my valve cover is still leaking a good bit, the seal, but I may have to live with that, I have not found a suitable alternative to the gasket.
Third, parking brake lost a horseshoe clip for mustache spring, and broke the return spring.
Fourth, need to do the rear axle pinion seals; this I knew about before, but have been lazy with.
I am pretty sure there was something else, but I can't remember right now.
Here are a couple pics, my 1985 GMC is taking up the garage space, so I made do outside, doing 1 wheel at a time, making sure tires were chocked, and everything sat firm
Ha, took a pic of the last issue, one of my boots is all cracked, I am pretty sure this was the side that was rubber one piece, I'll have to go back through my thread and verify, but I do remember getting one silicone and one rubber boot. What I will do is get a zipper boot for now till I get the 85 GMC on the road, which will hopefully be in another month or so
