Another Ahab
4,565
Alexandria, VA
So what I didn't mention after I posted the video of taking the M998 to the Hillman MudFest was that I managed to break the u-joint for the front driveshaft on the transfer case... When that went, the axle took out the t-case shift linkage and put a new permanent drain in the t-case.
I wasn't alone this weekend in having mechanical failures going through that mud. I saw two transmissions get smoked and saw four trucks loose their rear driveshafts on Sunday. There were countless other trucks that were disabled in the mud with electrical issues or blown motors.
Good times!
"Good times!"
That's pretty funny.
Retiredwarhorses
4,185
Brentwood, Calif
So if anyone has a 218 t-case around, please PM me. Thanks!
Good times!
I have a few 218's in the shop...do you just want the case or the entire assy? These would pay require opening and resealing the case and new seals. Can't vouch for the cooler loop either.
orgnal
Denver, CO
Bulldogger
586
Quantico VA
Drained and filled the differentials. Drove back and forth in each gear selection to be sure of trans fluid level and topped off.
Installed a battery cut off switch.
Noticed the coolant temperature got to nearly 220. But I already planned to drain and fill the coolant system and replace the thermostat so that is close to next.
After the coolant system I probably won't be able to find any more excuses to not remove the wheels and open and inspect the hubs.
Bulldogger
hummer4x4guy
Lansing, Mi
Bulldogger
Have you looked into www.evanscoolant.com. Switching my truck over to that.
infidel got me
32
Newberry, Florida
hawt hawt hawt
The evans fluid does look like a good deal, but I would think that a screw on coolant filter kit
would get you more bang for buck. We install these on all the diesels that we own. You wont
believe the crud that the filter will catch. A cheap investment, can be had on e-pay for under
a hundred bucks.2cents
hummer4x4guy
Lansing, Mi
I'm switching not because it keeps the coolant cooler but because of the other factors their coolant offers. It was only a suggestion.
hummer4x4guy
Lansing, Mi
Do you have a particular filter you use on the humvees specifically?
sully199
coral springs Fl
The seats look amazing. What seats are these and where did you buy them?
McReddy
Global Seating LLC, Vehicular Seats, They are for the MRAP, they are great. I removed the blast proof metal off the bottom from all 4 seats, they were 30 pounds each. They are still heavy, but I am able to move them forward to get to the batteries and storage in the back.
infidel got me
32
Newberry, Florida
hawt hawt hawt
It is a wix coolant filter. I was not trying to knock your recommendation of using the evans coolant-- I was just mentioning the added protection of a coolant system filter. Hope there was no misunderstanding. The kit is actually for 6.0 Ford trucks, but will adapt to almost any vehicle.
hummer4x4guy
Lansing, Mi
No I have no issues with the suggestion of a filter since Evans isn't designed to filter its self I like the idea. But is it like an online filter?
hummer4x4guy
Lansing, Mi
It's my opinion that with the cost of keeping a truck/Humvee for now going on 15 years I have no problems using the best for the truck for the next 15 and if people would look into it I think they will see the benefits. But if not it's not a problem. I just wanted to share with others Incase some haven't heard about it. :)
Bulldogger
586
Quantico VA
Drained and flushed the coolant system. Only got about 2.5 gallons of coolant out of it, which explains what I thought were high temps. She was running >220 and climbing when I shut her down during driveway ops after the drain and fill of transmission, transaxle and differentials last week. I've not taken her anywhere but the driveway yet, pending finishing the entire LO and other system checks. Thermostat looked good, but got replaced anyway along with its gasket. Took FOREVER to get the old gasket material off. Saw some deposits around the top hose connection next to the thermostat housing. I suspect she was leaking by there. I cleaned the fitting well and it is long enough to allow me to use two hose clamps to ensure tight fit.
Coolant hoses aren't great so will get generic fit curved hoses from Advance Auto this week and cut to fit. Then refill her with fleet diesel coolant and water 50/50.
Should be fine after that. I'm glad Advance had the Hummer H1 thermostat in stock along with gasket. I did have to drive to one a few miles farther away than my local store, but here in NOVA there are so many shops that having to drive to another one only means 7-8 miles.
So far so good.
Bulldogger
Retiredwarhorses
4,185
Brentwood, Calif
Fired up the new GEP 6.5 motor with 4L80E factory conversion yesterday....she runs like a raped ape and shifts beutiful.
This customer will be a happy camper...at least till he gets the bill anyway...
