- 2,112
- 555
- Davis County, UT
I've put air-assist steering on my M35A2 (besides partially wishing I had went actual power steering), performing low speed maneuvers in a parking lot, or while driving off road over rocks and ruts consumes a lot of air. Typically, this triggers the deuce's low air-pressure buzzer, which is the same point the air-assist is automatically disabled, and this can be tiresome by the end of the day.
I'm not to the point of adding larger/more air tanks to my air system yet, but I though that perhaps adding an additional electric air compressor would noticeably help out - if possible. I do have a separate 12V alternator with a third, dedicated battery for 12v accessories (I didn't want any issues with said accessories the ability to start and run the whole truck).
So, is it possible to just connect another compressor to the air system without adversely affecting the operation of the stock air compressor?
If so, two lines of thoughts, a manual switched, on-demand, air compressor for the tight maneuvering situations such as this (just two examples):
Or a "always on" or "always available" air compressor (just two examples):
As long as the added electrical air compressor could be set to "turn on" and "turn off" about the same time as the stock air compressor (or turn on later, at a lower pressure), do you see any problems with this? Which type of system would you go with? Obviously higher CFM and duty cycle systems cost much more.
- ARB CKMA12 (2.65 CFM @ 0 PSI, 50% duty cycle) - $275
- Viair 40040 400C Air Compressor Kit (2.54 CFM, 33% duty cycle) - $173
- ARB CKMTA12 '12V' On-Board Twin High Performance Air Compressor (6.16 CFM @ 0 PSI, 100% duty cycle) - $518
- Viair 45040 450C Air Compressor Kit (CFM @ 0 PSI - 1.66 / CFM @ 100 PSI - 0.94, 100% duty cycle) - $192
