Lawdog734
- 101
- 43
- Colbert, GA
Much progress on the transmission today. Sealed and bolted the NP242 and adapter to my 4L80E, put together a new speedometer adapter, and prepped everything to be lifted in. Unfortunately, my lift has failed me and is leaving me a few inches short of target...
I now need to either find someone I can borrow a transmission jack from that lifts to about 20", bite the bullet and buy one, or take the risky venture and use cribbage on top of my current jack to get the transmission up that extra few inches I need...
Tool rental store might have a transmission jack......pawn shop.....just sayingMuch progress on the transmission today. Sealed and bolted the NP242 and adapter to my 4L80E, put together a new speedometer adapter, and prepped everything to be lifted in. Unfortunately, my lift has failed me and is leaving me a few inches short of target...
Just what I ended up doing. Every pawn shop was closed today and nobody on Craigslist replied back, so I found one tool rental place that was open an had a transmission jack. $52 later, I'm back in business.Tool rental store might have a transmission jack......pawn shop.....just saying
Neat idea. It'd be pretty weird riding back there in that seat with the fixed door and troop seat back against your side....but not impossible. I figured that I might use my rear seats some day with the fixed door and troop seats removed in order to seat four while doing some off-roading without springing for the four-door top.Trimmed off some of the troop seats so I can have them down and still have my rear passenger seats up.
Thanks. I like it better that way but I mostly pull the pins and keep the seats in the garage.Neat idea. It'd be pretty weird riding back there in that seat with the fixed door and troop seat back against your side....but not impossible. I figured that I might use my rear seats some day with the fixed door and troop seats removed in order to seat four while doing some off-roading without springing for the four-door top.
Y'know, I just noticed that your wipers are parked on the left, but mine and all the others I've seen are parked on the right.Thanks. I like it better that way but I mostly pull the pins and keep the seats in the garage.
Just took her out and did about ten miles. It was 82 today and the cooling system works great.
If they operate full-swing, remain mostly parallel to each other through their entire travel, and always stop at the same spot, then nothing is functionally wrong with them...just the way they setup the linkage is a bit odd. If it doesn't bother you while driving, I'd personally leave it be and just enjoy your snowflake. Heck, make up stories about how it's out of a right-hand-drive HMMWV.Thinking about it now. There's something weird there... linkage in the windshield is incorrect. Right?
my truck has a brand new wiper motor.. I'm guessing they hooked the linkage up wrong at the base.
