riderdan
- 20
- 18
- Central Kansas
I put the antennas on my truck today and got the VIC attached to the radio deck. Unfortunately, it's raining down buckets, so no photos. Maybe tomorrow.
I've been VIC shopping for some time, looking for that elusive deal. Yes, we'd like to see your install photos....rain or shineI put the antennas on my truck today and got the VIC attached to the radio deck. Unfortunately, it's raining down buckets, so no photos. Maybe tomorrow.
I have a tough to find vic vertical mounting plate for the radio shelf on dog house. Also have radio shelves. if interested, please pm.I've been VIC shopping for some time, looking for that elusive deal. Yes, we'd like to see your install photos....rain or shine
Looks like you may end up with an extra 4 knob box. If you do end up with an extra LMK .Had a little free time today and pulled out some of the VIC 3 stuff and loosely installed it. Need to get some hooks or something to hang the headphones from the turret ring and find the bracket to mount the rear box on the turret ring.
Did not want to mount it fully as the radio tray will have to be removed when I get a new engine which is next on my list just need to find a 6.5 na that's ready to drop in.
Thats enough boxes to do two six man systems.Had a little free time today and pulled out some of the VIC 3 stuff and loosely installed it. Need to get some hooks or something to hang the headphones from the turret ring and find the bracket to mount the rear box on the turret ring.
I have to admit, I'm a little jealous. Nice set up
No complaints about the oil. I use rotella 15-40 which is always cheap at walmart. I've never seen a loose fill cap but the dip stick never fits that tight. My only thing is I never use Fram. You can pull up some of the horror stories from their cheap drain back valves and paper components inside. I use the Mobil or Bosch filters which are only a few bucks more and have a lot more weight to them.Got my first oil change under my belt. Use the FRAM PH5 filter and this oil on sale until today at Costco: View attachment 681199
And it's literally my first oil change. 3 questions:
1. the oil sure did stink like burnt, well "burnt" actually covers it, this unique to me? or common?
2. Anyone have any issue with the oil used?
3. How exactly is the oil fill cap supposed to fit? Mine's super loose.
Thanks for the tip, this change is only going to be 500 miles and I'll switch up filters next go around (want to get 2 quick changes under my belt before slotting into a normal schedule)No complaints about the oil. I use rotella 15-40 which is always cheap at walmart. I've never seen a loose fill cap but the dip stick never fits that tight. My only thing is I never use Fram. You can pull up some of the horror stories from their cheap drain back valves and paper components inside. I use the Mobil or Bosch filters which are only a few bucks more and have a lot more weight to them.
Sam's tends to have even better prices on Rotella.No complaints about the oil. I use rotella 15-40 which is always cheap at walmart. I've never seen a loose fill cap but the dip stick never fits that tight. My only thing is I never use Fram. You can pull up some of the horror stories from their cheap drain back valves and paper components inside. I use the Mobil or Bosch filters which are only a few bucks more and have a lot more weight to them.
