ryanruck
- 46
- 28
- Cincinnati, OH
How much crap came out when you flushed the system?Nothing exiting to report: Performed a radiator / cooling system cleanse, changed out the radiator and heater hoses ( that short one is a PITA) and filled with new coolant /water mix. A man just feels better knowing none of those new components should fail him in the next several years
Lets see a photo of this I'm curious what it looks like!Walmart bicycle section cup holder... Holds 12oz bottles perfectly!!!!!
There really want much crud in the cooling system, a welcome surprise. With no way of knowing when the last service took place, better to be safe than sorry. Good idea on the dome lightHow much crap came out when you flushed the system?
Wanted to show you guys what I thought up for the dome light when I don't want to light up like day. The wiring is ran through the B pillar and ran to the brightest dem on my service drive, so I can switch it on without running an extra switch.
Bet your heater works better!Also flush heater core at same time. Mine had a good amount of crud and more came out when I removed heater hose and back flushed.
Lets see some pictures...Started to hang and paint my xdoors.
How do you like your turtle top?View attachment 691084View attachment 691085View attachment 691086View attachment 691087
Replaced std doghouse with turbo doghouse, added foot extensions to radio tray to fit turbo doghouse, and added a pair of fans. Plan is to fit a couple extra layers of Dynamat in turbo doghouse and see if it quiets things down any.
The fans are a welcome touch this time of yearView attachment 691084View attachment 691085View attachment 691086View attachment 691087
That's pretty crazy (in a good way).I made a new sound system out of 6 inch pvc pipe and used a swiveling marine grade radio housing to house the radio. its really **** loud I can actually hear it over the truck going 60mph . View attachment 691186
