- 2,112
- 555
- Davis County, UT
I remounted the Pioneer Tool Rack and one of the new air filters. It's a tighter fit than expected to get the shovel out, so a little bit of care is needed but it is still readily doable.
Before finalizing the wiring to the compressors, I'm actually finally going to mount the two 24" Ibis Tek light bars I bought years ago. Most of those specific updates will be placed in my Ibis Tek light bar thread.
One will mount below the bed in front of these air compressors, and the other will be on the opposite side above the fuel tank. From my test fits, I believe it won't add much to the finagling of getting the shovel out, which probably won't happen much anyway. I hope the light bar will actually help shield the air compressors from additional dust. It probably won't be much, but some would be a decent trade for the slightly added servicing difficulty.
The light bar will actually be mounted closer to flush with the bottom of the bed, but it's a bit challenging to hold both the 8lb light bar in place and take a picture.
