riderdan
20
Central Kansas
Got the driver's seat cover from Jatonka installed. I need to pull it a little tighter, but it's very well made and a good fit.
I also added these flip up steps to the rear bumper.
I spent a few years jumping out of planes and was in a pretty bad motorcycle accident a while back and have the devil of a time getting into and out of the bed. Hopefully these will help
Bulldogger
701
Quantico VA
Where did you get the step from? I like it.
I saw that and had to have it. Found the best price at a website called Zoro. The Surplus warehouse has a good price, but shipping was almost the same price as the two steps I wanted. Amazon has it, but at nearly $15 each with Prime.
At Zoro I was out the door with two of these for just under $20. I look forward to putting them on.
BDGR
someoldmoose
Lancaster, PA
Found these on TrucknTow.com if anyone prefers stainless or shiny. $22.99 ea. ss stephandle.jpg Just sharing. Saw while shopping for the cable style ladder / step for the front of mine.
orgnal
Denver, CO
Share pictures of where you mount the folding step
McReddy
riderdan
20
Central Kansas
I decided to put it outside the swing of the tailgate so I can still use it if the gate is down. It's a little hard to see, but it's right above the reverse light.
shawnshumvee
Janesville WI
I finally found my block ID numbers. I was looking in the wrong place. It's a 2003 GEP engine. My truck is an 86 model. I think I got lucky...
Yes you did! My engine is 2005 6.5 GEP. Inside the valley (under the intake) you should a 503 casting ( made up of a bunch of dots), if so i believe that's a Novastar casting. one of the best. they fixed all the issues the GM 6.5 had.
lowell66dart
Paulina La.
According to the internet.....GM actually got it right toward the end but gave up. The Navistar (spelling?) foundry was chosen because GM was having to replace too many Humvee engines. These folks made all of the Powerstroke blocks I think.
From what I can gather the 6.5 NA are pretty much bullitproof if kept cool which is why I'm running a 160 degree thermostat. I have to run it hard to get it to move off of 180 degrees.
98G
Former SSG
4,650
I'm not sure it's a matter of keeping a lower overall operating temp. I think it's more a matter of preventing localized hotspots.
Keeping the whole thing cooler may keep the hotspots less hot, but I still think the primary concern are those small pockets near #8 that get hot. I speculate that faster circulation may go further towards this than cooler coolant....
(Comments welcome)
orgnal
Denver, CO
(Comments welcome)
I agree with you
McReddy
911joeblow
72
Utah
(Comments welcome)
You are very correct. The rear block design and the overall coolant flow pattern on these blocks leaves a lot to be desired. Of course most on here know about our Cooling Upgrade Kits to fix this. We have a blog which describes the issue in detail here:
https://paradoxbydesign.com/blogs/news/the-humvee-diesel-engine-cooling-paradox
The kits for HMMWV trucks, both 6.2 and 6.5 and 6.5T are here:
https://paradoxbydesign.com/collect...oducts/hmmwv-humvee-cooling-upgrade-system-v3
Action
1,561
East Tennessee
But someone did do a temp test with the kit, and the rear of the block got hotter with that kit installed. IIRC. Then the maker came back and said it didn't get cooler, but it evened out the temps?
Of course we know about your kit, you advertise in on every cooling thread, and more. Isn't this what the FOR SALE section is for?
