Lovetofix
- 63
- 18
- Morrison,TN
Per the -20 there is no 100 lb-ft used.After your 100 foot pound load while spinning then back off then setting preload at 50 foot pounds how far are you backing of that?
“Continuously turn wheel (3) while tightening inner adjusting nut (4) 50 lb-ft (68 N•m), then back off inner adjusting nut (4) 1/4- to 1/3-turn.
Install adjusting nut washer (2) and adjusting nut (1). Tighten outer adjusting nut (1) 250-400 lb-ft (339-542 N•m).”
Since I was reusing my bearings I went with the 1/3-turn back from 50 lb-ft. If they were new I would back off a 1/4-turn and to the next hole in the locking ring.
