- 1,102
- 1,633
- Wilson County, Texas
Definitely will share once it comes in on how it fits & what I did.Colt,
When your tank comes in, I'd like to see that too. I'm in no hurry for that info, but was thinking about it while trying to figure out a decent way to hook up an external tank in my situation. I'd *really* like to have a larger onboard option given all the extra space on the trailer.
Thanks,
SJ/JD
I have 2 ways of hooking it up in mind... spring locked ball valve or a 24v solenoid. Ball valve would just be manually opened when needed. The 24v solenoid could easily be wired in series with the auxiliary fuel pump. When the pump kicks in, the solenoid opens.
The fuel fittings use a 5/16 37deg JIC fitting. Was going to get a hose made with a 90 deg fitting to attach to the auxiliary port of the generator & then run it to the valve from the fuel feed of the tank. Secure it along the way with the panel bolts that cover the fuel tank area.
Also will be putting a hand pump for using the tank to fill the ATV, Tractor, & if needed my truck... or anything else that takes diesel for that matter.
Looking forward to it. Tank should be shipped soon.
