Rmtaunton
31
Smyrna, ga
And now I need the hydraulic pump, crank pulley and fan , oh and duel voltage regulator
They broken when it was originally pulled let me know if you have any or where to find
Thanks folks
Robert
Wire Fox
161
Indianapolis, Indiana
Rmtaunton
31
Smyrna, ga
NormB
72
Cloverly,MD
Changed out the 60A alternator to 200A months ago, got everything assembled, belts tight, etc. Scrounger stopped by for the alternator, I asked him if he thought everything looked right, he thought the belts looked a little loose. So I tinkered w/ them a bit, gauge WAS showing they’d stretched, then they stretched some more.
Tightening the PS pump belt is NOT an easy one-person job. The $15 3-D printed 1/4-20 threaded rod adjuster gadget I got off of ePay broke at about 40 lbs. Worked the first time. So what else? 1/2” breaker bar from the bottom? Just TRY and get a good angle while the truck’s parked, not on a lift; even at that I don’t think it’s easy.
This made it easier:
Got the PS belt to 90lbs, then got the alternator/waterpump trio to about 90lbs, give or take about 15 lbs. Meaning the belts, while “matched” don’t all read the same. Within specs, however.
For the generator I used what I did before, a 3/4” round breaker bar with a four-foot galvanized steel pipe I used to adjust barrel alignment on FN-FAL receivers many years ago.
Good to have more than one hobby.
Improvise. Adapt. Overcome.
[h=1]“Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. ”[/h]Archimedes
therooster2001
44
Colorado
Oil change and tightened up the transmission pan. 12 ft / lbs is not a lot, but the bolts tightened up, hopefully that will stop my minor drips that seem to have developed over the past couple of months.
I did notice that when reversing and applying brakes it felt like more noise then when going forward, but maybe it’s the engine noise drowning it out. Either way, feels like I need to check brakes just to be sure.
I had not been able to drive it for three months. I did miss it.
NormB
72
Cloverly,MD
I bought a 2" strap wrench to tighten the alternator with 10 years ago. Still works great!
Any particular make/model you recommend? Please don’t say Snap-on.
If I had my life to live over again, I would’ve started buying snap-on tools at yard sales/flea markets when I was 20.
Now? This close to retirement I can’t justify the price for the amount of use I might get and my kids just aren’t hands-on mechanically-inclined enough to deserve an inheritance like that which would likely wind up at a yard sale anyway.
Another Ahab
4,556
Alexandria, VA
TOBASH
3,488
Brooklyn, NY
Looks like a control rod for a rear end of a fully adjustable rear axle. Readily available but "some assembly required" Great idea!!!
Frost0071
Indianapolis/Indiana
That's a pretty work of machining! Did you contract it, or do that yourself?
And are there internal threads of some kind for the loosening. tightening?
Thanks. I made it out of an 1" hex bar and cut some LH and a RH thread for 1/2"-20 ball joints through it which makes it now pretty easy to get belts tensioned.
I might build me version 2.0 sometimes with some little improvements but I don't plan to sell this. If somebody would like to build it I could make a drawing.
TOBASH
3,488
Brooklyn, NY
Drawing would be awesome.
Specifically identifying ball joints and source and tap/dyes and source and length of hex rod and source.
