- 1,199
- 455
- 83
- Spartanburg,SC
Added hood lift struts.
Any part numbers or other details to share?Added a seal to help keep water out of the engine valley. Just had my IP overhauled because of collecting water there.
This is what I used.Any part numbers or other details to share?
BDGR
I had some big holes with wires coming through them in mine as well. I plan on putting grommets in, but in the meantime I used liquid electrical tape to fill the holes and keep the wires from rubbing. Working great. Keeps the big splashes out when playing in water.I drove on the beach a week ago.
Past couple days it's rained pretty good, some of the roads had water over them.
I used it as an opportunity to rinse the undercarriage of the truck.
Turns out, the holes from the RedDot system wires WILL allow water in, and if you're going fast enough it will splash off the ceiling and all over you.
Lol. Would of been nearly impossible with brush guard up. Just put it up to pull back in garageIt might have been easier if you dropped the brush guard!![]()
It really IS nearly impossible with something up there (but it can be done)… one of the hinges on my hood will not come out so I had to do mine with my hood on and that was a nightmare! This is the reason that I do not want to take it back off right now. I need to get to the hose that goes to the fan clutch, but have been unable to reach it so I know one day soon I will have to take that stack loose again.It might have been easier if you dropped the brush guard!![]()
I got to the QD end of mine under the truck. It wasn't fun but doable.It really IS nearly impossible with something up there (but it can be done)… one of the hinges on my hood will not come out so I had to do mine with my hood on and that was a nightmare! This is the reason that I do not want to take it back off right now. I need to get to the hose that goes to the fan clutch, but have been unable to reach it so I know one day soon I will have to take that stack loose again.![]()
Next time you mess with that hose, install the quick detach coupler. You'll be praising yourself for that official mod every time you look at it. Makes it possible to quickly disconnect the clutch without losing any fluid or needing to bleed the system.It really IS nearly impossible with something up there (but it can be done)… one of the hinges on my hood will not come out so I had to do mine with my hood on and that was a nightmare! This is the reason that I do not want to take it back off right now. I need to get to the hose that goes to the fan clutch, but have been unable to reach it so I know one day soon I will have to take that stack loose again.![]()
Where did you get the x-door skins?Santa finally showed up with my x-mas x-doors
