joshuak
- 214
- 43
- Slower shore, DE
Exhaust
Got a bit further in my effort to increase exhaust diameter. First order of business was removing the exhaust manifold studs, there is only 3 per side, I thought I'd be done in a few hrs. for sure,
. Broke the first stud I put the extractor on. So, off came the manifolds, out of the 16 bolts 14 cooperated, the other two got the sawzall treatment. Thankfully the extractor got those out without an issue and I avoided having to pull the motor.
Example of offending bolt.
Back to the studs, for the PS I was impatient, par for the course, and recurred to physical methods (drilled and tapped two of them and welded a nut on and backed the other one out.
![IMG_3209.jpg IMG_3209.jpg](https://www.steelsoldiers.com/data/attachments/514/514144-513f7d18310db15759cbeb3331bd1c15.jpg)
![IMG_3211.jpg IMG_3211.jpg](https://www.steelsoldiers.com/data/attachments/514/514145-f0f907a3329385978ca741b4f3dfc9a5.jpg)
The DS studs soaked in acetone and ATF mixture, 50/50, only 4 hrs. and came out easily. So no pictures, hopefully I'll learn.
There was no gasket on the manifolds when they came off, I used one when they went on. FelPro 91587, pictured bellow next to a 3/8" spacer for another project.
And here are both manifolds installed. On the PS, you can see how the 2 1/2" pipe bolted on the manifold steps up to 3", I drilled and tapped the DS flange to accept an EGT probe (Auto Meter 2654).
![IMG_3223.jpg IMG_3223.jpg](https://www.steelsoldiers.com/data/attachments/514/514148-ee7cd96fe9579b5795b5dc80bee1e027.jpg)
![IMG_3222.jpg IMG_3222.jpg](https://www.steelsoldiers.com/data/attachments/514/514147-d64d0b5b212635ed5b0087067352913a.jpg)
I'm currently working on routing the exhaust. New vs old.
![IMG_3218.jpg IMG_3218.jpg](https://www.steelsoldiers.com/data/attachments/514/514149-be99967646a05c69dde755e39a154e58.jpg)
![Razz :razz: :razz:](https://www.steelsoldiers.com/images/smilies/icon_razz.gif)
![IMG_3205.jpg IMG_3205.jpg](https://www.steelsoldiers.com/data/attachments/514/514141-131668487b3597e9045855bbd6ee0ea6.jpg)
![IMG_3206.jpg IMG_3206.jpg](https://www.steelsoldiers.com/data/attachments/514/514142-62bddeb3729daa619822196436902a37.jpg)
![IMG_3203.jpg IMG_3203.jpg](https://www.steelsoldiers.com/data/attachments/514/514146-8746e74fed9b3b0c803e7ff1b59e98ab.jpg)
