MEP-803a "click" no start
Light in the Dark
5,945
MA
They are not designed for any additional backpressure which would come from such an addition... I would not do it. These are very quiet sets... not hospital grade quiet, but damn quiet to me. Do you find yours is loud??
mchlsprgn
14
jamul cal
No, just curious . my gen is under a roof need to run it up should I use larger dia pipe?
Light in the Dark
5,945
MA
Thats your call... set was designed for the pipe size as is. Larger shouldnt be a penalty (typically isnt on diesel systems as they do not want backpressure). I would just make sure you do not have needless angles or bends in the exit pipe.
Also if you run additional piping, you will want a flexible section of pipe somewhere in line to basically dissipate any excess NVH (noise, vibration, harshness).
mchlsprgn
14
jamul cal
ust me
The roof is 8-10 feet above gen no walls no problems . I could a run a 6 inch flexable line. I'm just looking for something to do BORED IN JAMUL
