- 6,426
- 4,983
- Ft. Lauderdale, Florida
Clips on bottom rot away, felt wears out, stuff fails. Protect back of hands good, it is tight space in there.Forgot to mention I rolled down the driver window and it went clunk and the hand crank just free wheeled. I could pull the window up but it wouldn't engage. Took the access cover off and couldn't see much but eventually got the scissor frame down and one of the sides was off. Put that back together and it cranks now all the way up but only comes half the way down. It like it gets jammed. I can't see much so I have no idea what is getting stuck. The TM diagram shows the parts so I guess I will have to tackle that when it gets warmer again, snow today so back to winter!
Me thinks if these things where ever greased then they wouldn't fail.
Mine took only 50 years to fail, they don't build them like they used to.
I paid about $2.50 each back then, thought that was outrageous but can not make them.
Now this is outrageous ........................... shop 'till you drop.....
M35A2 M939 WINDOW REGULATOR CLIP M818 M813 M932 M35A3 M109A3 M923 M925 M931 | eBay
THIS SALE IS FOR ONE NEW WINDOW REGULATOR DOOR GLASS FASTENING CLIP FOR ALL 2.5 TON AND 5 TON TRUCKS. MILITARY PART NUMBERS ARE USED FOR REFERENCE ONLY. I HAVE ACCESS TO HUNDREDS OF NEW MILITARY VEHICLE PARTS AND CAN PROBABLY FIND YOU WHAT YOU NEED!
www.ebay.com
