- 488
- 366
- 63
- California
Exactly right! I did say that mine is longer and offered to drive to their place so they can see it and maybe make some like Mogman said, but they said, no need we are already making them, it's on our web site (the short one).Yup, radiators that go in the turbo H1 are not the same length as the ECV turbo HMMWV.
So if you call a company and look for a radiator for a turbo HMMWV, you may end up with a shorty. Some folks dont know the difference between humvee and H1.
BTW Action, you seem very knowledgeable, I am thinking to remove the engine bay side panel to get access to the radiator front corner, where the leak seems to come from, I could also feel there are some hoses underneath, on the other side of the panel, and maybe that's what's leaking and not the radiator as it happened with several fuel hoses so far:
Please see my comments about the two screws & bracket in question that I am thinking to remove instead of the screw above that appears to be held by a nut on the other side which I cannot reach without removing the whole radiator and heat exchanger, which is what I am trying avoid.
EDIT: I meant, "Instead (of removing the top bolt held by the other side nut), reamove bracket held by the two screws below" (forgot the comma after instead)
What do you think/ recommend?
