- 3,080
- 4,579
- Olympia/WA
just remember that stainless steel and aluminum don't like each other, so if you are in a wet or salty environment you might have some corrosion issues.
Thank you for the advice, Coug. Yes actually, I live right on the coast. I am familiar with Inter granular corrosion, and it will be prevented/mitigated by adequate means.just remember that stainless steel and aluminum don't like each other, so if you are in a wet or salty environment you might have some corrosion issues.
Just wanted to make sure. I've seen too many people post things where they think because it's "stainless" that it will never have any type of issue no matter what they do with it.Thank you for the advice, Coug. Yes actually, I live right on the coast. I am familiar with Inter granular corrosion, and it will be prevented/mitigated by adequate means.
That is a twist of luck. LOLNote to self when running wire harness: before contortioning under the truck and fishing cables up & down, make sure to check there is NO KNOT in the middle of the harness!
I could not sleep at night until that's fixed....Note to self when running wire harness: before contortioning under the truck and fishing cables up & down, make sure to check there is NO KNOT in the middle of the harness!
It circularly polarizes the electrons for increased speed and decreased resistance. It's a design feature.I could not sleep at night until that's fixed....
I've heard a common failure for wiper motors is the power wire getting pinched at the bottom of the windshield where the windshield folds down. If yours was folded down at some point, it could have pinched and cut that wire.878052[/ATTACH]
Today and some days before... bringing my rig home..
View attachment 878045View attachment 878046View attachment 878047
Done some inspections... especially the spindels. Found some hand-warm or loose bolds on the half shafts inner and outer side.
But the spindels were all correct secured.
Installed the antenna
Installed the Arktic top.
View attachment 878051View attachment 878053
Fixing two half shaft boots. Both inner side rear left and front right.
Need some brain to figure it out how to disassable the axle. Need to fill all this by using the inner side of the half shaft. Strange!
And realize that the 10k A2 trucks have 12k axles. And the boots from the 10k are 1cm smaler in diameter!
View attachment 878055View attachment 878056
what a mess... I will be very happy when the parts come today, I have everything back together and can finally clean up the bench.
And right now... i have to figure it out why my windsheeld wipers not working. Even with a new switch.
It normally is bad contacts where the windshield contacts the cowling. since you have no top it is easy to fold down the windshield and clean them
You could put a small brass washer on top of each contactI was able to replace the contacts and seals by just prying the windshield frame up a couple inches and didnt have to disassemble any of the hardtop. After finishing, it seemed that if one does not intend to do any windshield folding, it would be best to just hard wire those connections. I will also add that first I tried cleaning up the contacts which worked for a short amount of time but since the rubber was aged, the lower contacts were depressed lower than they should be and the rubber was not pliable enough to keep upward pressure. New contacts are here, amoung other places.
Contact Assembly Windshield Wiper Motor Lead
Real4WD - 12339327 - Contact Assembly Windshield Wiper Motor Lead 5999011839530, NSN 5999-01-183-9530real4wd.com
Not so much pinched or cut... but there are contact areas (small button) that when the windshield is up, come together. Age, rotting rubber and corrosion work at making for a bad connection. Many owners never see them or lower the windshield.I've heard a common failure for wiper motors is the power wire getting pinched at the bottom of the windshield where the windshield folds down. If yours was folded down at some point, it could have pinched and cut that wire.
Bulldogger
