- 753
- 1,331
- 93
- Highland, Indiana
New Truck Lite Led headlights.
![](http://uploads.tapatalk-cdn.com/20230218/e7f2ae397a4ef035fe2a731e6e2238c7.jpg)
.Operation: Co-Pilot Traction Enhancement...
Made a template. Transferred it to a horse stall mat. Cut it out w/ a jigsaw. Beveled the edges w/ a router round-over bit. Installed. Fit like a glove. Co-pilot approved.
How easy was it to swap the blackout for the IR? was it a simple plug and play or did you have to rig the wiring to make it work?Installed new headlights, and swapped the blackout driving light for an IR light
The wiring is already there, just need to swap out the connectors.How easy was it to swap the blackout for the IR? was it a simple plug and play or did you have to rig the wiring to make it work?
thanks, Stephen
.Been a bit busy.
Made a couple videos
Painted my entire Humvee Camo for under $150
Walkaround
Bought and installed (didnt connect) some new LED accessories.
Thanks..
Good looking paint job!
Finally got the hood painted/replaced and the driver's cowl panel painted/replaced. Did some half ass touching up with rattle cans and not done yet. Got my Blue Ox Top installed, but the curtain hasn't been installed yet as I'm moving the rear seat belts for a cleaner look. All new LED lights install except for the BO light which doesn't seem to work (trucklite headlights, brake, and front amber). You experts on here can attest likely that nothing goes as planned with these rigs. And, true to form, the rear LEDs got install and now crap doesn't work. Turn signal doesn't flash on right side on service drive as of today. Yesterday, the turn signal didn't work at all in service drive. Right rear break light didn't have same number markings on wires to match the tags on truck. Posted some before an after photos.
Have not yet installed window hardware. Only pic I have of inside. Flat aluminum so far. When ordering doors IMore pictures of the doors please! How does the inside look?
