- 16,760
- 24,065
- Burgkunstadt, Germany
Could you please give me more information on the locater which is in the plug? My plug is kind of jacked up and probably will require me replacing the entire plug if I don't bypass it and solder connect all the wires bypassing it. Thanks
What is a "Locater"
You need to look at the doors on the gen set. Schematics are there.
TM's are here: https://www.steelsoldiers.com/threads/all-the-tms-needed-for-the-mep-803a.213028/
The -24 has the schematics.
The -24P has the answers to your below asked questions. You may have to do a little research also.
I'm looking for the part numbers for P7 and J7. I willborder new plugs and pins and go from there but I'm not seeing them. Dies anyone have the part numbers to the plugs or know a place that probably sells them?
What is a "Locater"
