Helmet top install
Coug
4,580
Olympia/WA
How hard is it to install a helmet top on a ragtop m1123. Does it just bolt right on or do you have to switch out windshield frames etc
will bolt right on.
I don't think you have to remove the channel for the soft top at the front of the frame, but it's been a few years so don't remember exactly.
badgerd
Electronic Jedi
102
65
Chesapeake VA
You’ll need to remove the soft top channel from the windshield and the C pillar.
Installation instructions, for the Amtech tops, is the whole way at the bottom of the page here:
TexF18
36
omaha, ne
Thank you
Mogman
10,221
Papalote, TX
Make sure the rear side and rear "lips" are tight against the rear of the body, you may have to put a ratchet strap across the back to pull the bottom of the helmet top together so it fits tight against the body before drilling the holes for the rear mounts.
Guyfang
25,903
Burgkunstadt, Germany
I just installed one. It's relatively easy. Just make sure everything is aligned before you drill any mounting holes.
(More manuals are available on their website).
Please upload this Instruction book in the TM upload thread. I will then put it in the correct forum. Its good you posted it here, but in a year, no one will be looking here, but in the correct forum they will find it.
20,465
I pushed 3 books and 2 Latch books.
Temporarily located at:
