will bolt right on.How hard is it to install a helmet top on a ragtop m1123. Does it just bolt right on or do you have to switch out windshield frames etc
Thank youYou’ll need to remove the soft top channel from the windshield and the C pillar.
Installation instructions, for the Amtech tops, is the whole way at the bottom of the page here:
Legacy 4 Door - McClarin Composites
Helmet Hardtop® : Standard Convert your canvas top to a one-time permanent solution. Our Standard Top is our most popular model in the Helmet Hardtops® series with thousands in use by the Armed Forces today. In this configuration, the cargo area is covered, similar to a sport utility truck. We...www.mcclarincomposites.com
I just installed one. It's relatively easy. Just make sure everything is aligned before you drill any mounting holes.Thank you
Please upload this Instruction book in the TM upload thread. I will then put it in the correct forum. Its good you posted it here, but in a year, no one will be looking here, but in the correct forum they will find it.I just installed one. It's relatively easy. Just make sure everything is aligned before you drill any mounting holes.
(More manuals are available on their website).
.Please upload this Instruction book in the TM upload thread. I will then put it in the correct forum. Its good you posted it here, but in a year, no one will be looking here, but in the correct forum they will find it.
