- 1,532
- 1,757
- Puget Sound, WA
Either not enough belt or too much pulley!
12469149-3 is too longEither not enough belt or too much pulley!![]()
Yep, neither of those belts are correct for that pulley….see it all the time.12469149-3 is too long
12460226-4 is too short
Pulley next to oil filler is offset towards the back and misaligned with the rest
trying to remember which hole the alternator bracket should be bolted through, since the top bracket has 2 holes. That’s my only suspicion as to the belt length issue, I’ve already verified the right tensioner.
Really? Will have to figure it out with David then, I got both to test the length. I think I used 12469149-3 when swapping the 400 to a 200A a while back, gonna have to go back and check.Yep, neither of those belts are correct for that pulley….see it all the time.
Definitely takes patience to renew the original x doors, looking awesome.Finally starting body/paint work. Rapco 383 and epoxy primer. LF door rebuild & paint along with a few plates.
Tobash !! 2 decks of cheap cards woulda done that deal easy peasy....I’m not a fan, of tan.
Rims were dirty as heck from storage. Washed with water and a scotch pad. Chamois dry and then prep work.
Tedious part is taping off properly. Taping round rims with raised lips has to be done just right.
4 done. Six to go.
View attachment 901830View attachment 901831
Very coolI replaced the last of the original 7K half shafts on the DuraVee today, only 20,000 miles but 30 years old, I guess I can't complain.
As I have said before I use M10-35 flanged bolts and the larger Nord Lock 1528 washers, these things really cling!
And of course a new seal.
I have been putting allot of miles on the DuraVee without its usual once a month or so ride up on the lift for inspection because the FAV has been occupying that bay.
So I took this opportunity to pull all the wheels to do a tire rotation, service the hubs and give the chassis a good lubrication, GOOD thing I did as I found the Pitman arm is worn SLAP OUT!
Time to grab the TM and order a new one!!
Oh yes the disease continues to progress, I bought another HMMWV yesterday, a 1994 1097A1 man we are getting out of the Basics and all the way into the A1s!!
It is just a parts rig but I plan on installing that low profile helmet top on the DuraVee after installing AC of course...
I really like the look of the slant backs but you can't beet the helmet tops for leaks etc.
It also has rear doors that is handy as I already have front doors for the DuraVee.
I really like the look of the low profile helmet top over the "standard" helmet top, guess now I will have to get rid of the Detroit, nobody needs two helmet tops
That ticking sound means time to lubricate or change. Or alternatively it could mean you made some enemies and you should call the bomb disposal unit.Very cool
I still have those 7k half shafts at the back, my humvee has about 300k miles
They are starting to make ticking sound.
Is that Bias 36's on 12 bolt rims? If so that puppy must have come out of the smithsonian museum .....Oh yes the disease continues to progress, I bought another HMMWV yesterday, a 1994 M1097A1 man we are getting out of the Basics and all the way into the A1s!!
