- 551
- 874
- 93
- Texas Hill Country
2003 M1078A1 looking for a TM or ETM covering the ABS system. I thought I had found a live ETM for the A1, though apparently I am mistaken–
Possibly a dumb question but how do you hook up the laptop to the truck or the wabco controller?Thank you–
So, are there CAT and Allison cartridges for MPSI's pro link 9000?I never used a lab top but I use a prolink with a wabco cartridge.View attachment 908028View attachment 908029
Which of those things you mentioned actually connects to something on the vehicle? Is it that connector that's next to the driver's left knee? Is it a wire with that connector on one end and a USB plug or something to connect to the computer on the other side or is it some kind of wireless dongle?WABCO Toolbox:
Used with any laptop and a serial Dearborn DPA-III or a USB DPA-IV, or a NEXiQ adapter, etc. Any RP1210 adapter really
The Dearborn Protocol Adapters (3 and 4/4+) are what I use. Yes they connect to the port next to the battery disconnect switch in front of the driver's left knee. That port is a standard heavy duty diagnostic connection used by all medium and heavy duty truck applications. The DPA-3 uses a serial connection to the laptop (DB9) and the DPA4/+ uses USB.Which of those things you mentioned actually connects to something on the vehicle? Is it that connector that's next to the driver's left knee? Is it a wire with that connector on one end and a USB plug or something to connect to the computer on the other side or is it some kind of wireless dongle?
Thank you I guess the battery disconnect was included on later trucks I have a very early model A1 which is almost in A0.5. the only battery disconnect was over by the battery.The Dearborn Protocol Adapters (3 and 4/4+) are what I use. Yes they connect to the port next to the battery disconnect switch in front of the driver's left knee. That port is a standard heavy duty diagnostic connection used by all medium and heavy duty truck applications. The DPA-3 uses a serial connection to the laptop (DB9) and the DPA4/+ uses USB.
Those handheld scanners work OK for simple stuff, but the laptop software for CAT, Allison, Dana, and WABCO have more functionality, built in troubleshooting information, ability to program things like injector serial numbers (C7 trucks), etc.
Yeah, it can pretty much communicate with every ECU on the A1 3126 varriant.So, are there CAT and Allison cartridges for MPSI's pro link 9000?
Not trying to be a jerk but I see this theme on the forum over and over and over. "I am going to trouble-shoot a completely computerized system, without using the diagnostics in the computer" How much sense does that make?So, with no TM pages, nor finding any suggestions; started following wires, checking connections, pulling out the sensors to clean them up.
You are not being a jerk. I am in the wilderness here, learning new unfamiliar things; looking for just such a tool.Not trying to be a jerk but I see this theme on the forum over and over and over. "I am going to trouble-shoot a completely computerized system, without using the diagnostics in the computer" How much sense does that make?
Right now you could buy this on ebay and have the means to interface with every system on the truck. You would need a laptop with a serial port or USB to Serial adapter and software that members on the forum can give you and you are good to go. This person has make offer enabled so beat them up on their price and get the right tool for the job.
Adapter Kit, ICE Test Dearborn Protocol, Data Bus Kit, Probe Set NOS With Disc's | eBay
Find many great new & used options and get the best deals for Adapter Kit, ICE Test Dearborn Protocol, Data Bus Kit, Probe Set NOS With Disc's at the best online prices at eBay! Free shipping for many products!www.ebay.com
I did not find this helpful. Perhaps I am too slow to understand its use. The troubleshooting section refers to blink codes. Is the dash light supposed to blink? or is that somewhere else? Perhaps I gave up reading through this too soon—Have you tried this?
The reason I didn't suggest a sensor to check, is because that is a waste of time. Let me ask you this question. If your ABS ECU is complaining that you have a faulted ABS Modulator (and you don't know because you haven't pulled codes), what is the point of messing with the wheel sensors? Checking wheel sensors at BEST wasted a bunch of time, and at worst introduced more failures into your system by monkeying around with wires and sensors that didn't need to be touched. The point I am trying to make to you and anyone else who has problems with the computerized systems on the truck; is that wheather it is CTIS, the ABS, the transmission or the engine, the first and most important step to accomplish is pull the codes.@GeneralDisorder has criticized me as well. Though at least he suggested the sensors were the most likely item to first check.
Good! now you are well on the way to self sufficiency in troubleshooting.purchased, awaiting arrival to determine if usb to serial needs a male or female serial connection, and likely another laptop as hers probably has too new a version of Windows. Just what I wished to avoid>
Yeah not the greatest approach but that is literally what the military would do. Have some grunts clean the wheel speed sensors because in their experience it's the most common issue and often corrects the problem (ABS MIL). So for someone that has no capability to talk to the computer it's at least something you could relatively easily do if you're bored and just waiting for a scan tool solution.The reason I didn't suggest a sensor to check, is because that is a waste of time. Let me ask you this question. If your ABS ECU is complaining that you have a faulted ABS Modulator (and you don't know because you haven't pulled codes), what is the point of messing with the wheel sensors? Checking wheel sensors at BEST wasted a bunch of time, and at worst introduced more failures into your system by monkeying around with wires and sensors that didn't need to be touched.
I used that manual to reset my ABS ECU, for some reason my ECU was looking for an ATC valve and would disable ABS due to a ATC fault, I could only reset it by temporally wiring in an ABS switch.Have you tried this?
