M1078A1 "Pandora" Build | 2024-??? | ***Picture Heavy***
flyfishtrailer
1,030
Cool, CA
Your pump and the hand pump need to be rebuilt. There are several write ups in here on both. 20 + year old seals have gone bad. I know Colt did a video on rebuilding the pump, and I am sure there are also probably videos of rebuilding (or replacing) the hand pump. Have you checked the fluid levels in the pump reservoir?
Ronmar
7,246
Port angeles wa
F=MA… Oops wrong formula:)
PSI X piston surface area = force… You have to build enough pressure to lift the cab, ~ 1500PSI to be exact for a typical cab. Your pumps are obviously having issues doing that, or fluid is leaking from supply to return preventing full pressure Buildup. so as mentioned rebuild them. When y0u checked fluid level, did you check the hand pump/ it has a filler in the left front corner when facing the pump. The valving is supposed to keep it full, but that may not be functioning properly. Oil around the pump shaft is not a good sign though… The fact it opens the latch and lifts a little and that you were able to help it lift says it is making some pressure, just insufficient to do it unassisted.
aw113sgte
850
La Crosse, WI
InvictusDecretum
172
33
NC
You could buy a STE/ICE kit so you can perform the hydraulic tests required by the TM…..?
I have looked at buying one since I imagine I'll be doing many diagnostics on the truck but based on these forums, the software is the hard piece to find (along with the $600+ pricetag).
InvictusDecretum
172
33
NC
Thanks, makes sense the seals are toast. Sudden seal failure at these pressures is definitely possible, just wasn't sure that was the cause. I'll go the 2x pump rebuild route. Just finished reading this thread, found Colt and Fastidioud rebuild videos, and while the individual seals, u cup, and poly washer are "obsolete" from MRO, the full kit that Colt used was available so I ordered that.
Thanks for the explanation and confirmation RonMar. Your knowledge of the trucks and their systems is impressive. I've ordered an A/HPU rebuild kit (SPX P/N 300140) and 2x "exact fit replacement" washers for the now obsolete SPX P/N 17429 (SPX P/N HDT 17429)
I did consider an electric pump that met gpm and pressure specs you listed or that neat double action hand pump youre using in the rebuild thread, but Im not prepared to commit to that right now. Only so much money/time for research, learning, and doing and in this instance would rather rebuild the existing system in the interest of expedience.
Lostchain
577
Portland, OR
You absolutely need one of these for an A1, the DPA3 lets you interface with all the computerized systems on the truck. Software is available if you ask on the forum nicely. As far as the price goes, sometimes sellers will offer a lower price if you have it on your watch list. Also there is another seller on eBay selling a nice one for “make an offer” so you could go that route.
If this saves you one trip to CAT to read codes you’ve likely paid for it.
Lostchain
577
Portland, OR
Pretty much useless without the software to interface with it, which so far seems to be unobtainable for this generation of kit
Fake News, software is available see @GeneralDisorder statement above. In my personal opinion this is the better kit because all the implements are wired. I have this one and a newer Spiral Two and this is the one I go to.
InvictusDecretum
172
33
NC
Well, you and general disorder convinced me... time to eat Ramen for a month !
Lostchain
577
Portland, OR
Yeah that hurts, but not much on these trucks is cheap unfortunately. First time you program your CTIS or CAT ECM on your own you'll feel pretty good about yourself. I think @GeneralDisorder can even make you up a nice diag laptop with all the software preloaded if you aren't a techie.
Lostchain
577
Portland, OR
Also to power the interconnection box, which is what all the analog test pieces hook to, you will need this cable to get 24 volts from the slave port on the truck. You’ll need this to power up the hydraulic pressure sensor needed for the test #51 mentioned in the TM above. Normally that box is powered up by the diag laptop that originally came with this ICE kit.
InvictusDecretum
172
33
NC
Oh hey, one of suprman's listings (I believe). Picked one up as well. Don't have a nato slave receptacle on the truck but that's easy enough to re-terminate and power with whatever else. Looks like center pin is positive.
Thank you so much for your expertise/advisement on this. I obviously would not have known about that power cable, or probably picked up a seemingly complete/nice NOS STE/ICE DPA3 without your push. Going to hit up GeneralDisorder now to see if I can amazon a thumbdrive to his house and see if there are local beer delivery people.
Lostchain
577
Portland, OR
The DPA 3 is really the key to the whole thing, you gotta have a good data bus adapter to talk to all the computers that the A1 and up trucks have. All the other analog tools in the kit, could theoretically be fabricated yourself, but if you don’t have them already, why bother. For example the hydraulic test the TM wants you to perform. You could probably make your own with a gauge and source the right fittings but if you didn’t already have one, seems like a little project in and of itself that you might not have time for. I never worked on heavy trucks myself before I got my LMTV, so I was happy to get a kit with all the custom stuff I needed in one shot.
Good luck and be sure to let us know if you have problems getting it operational.
Ronmar
7,246
Port angeles wa
3000 PSI gauge, 1/4NPT female to JIC-4 male adapter and a JIC4 fem-JIC4fem swivel fitting, and you can connect to most things on the truck. About $30 at Surpluscenter.com? I just ordered some a week or so back for another project...
InvictusDecretum
172
33
NC
You sure it's JIC and not AN ?
AN would make more sense to me in this application, and the tolerances are more specific vs JIC.
About 10 years ago we lost power after takeoff in one of the aircraft I flew in after a parts supplier supplied faux AN fittings that were actually JIC. Given that a lot of components in a turbo-prop engine are driven on oil and pressure, and if you're losing it... just after takeoff... bad things start to happen.
How much practical difference does that make in a truck ? Not sure, probably none. But I do have personal experience with 2 different brands of JIC fittings not sealing completely in my diesel colorado. But with true AN fittings, you can mix and match suppliers.
