Pushing some white stuff. The truck handles it well!
.Well I hate to create posts like this, but I'll admit I'm an old poop and really slow and do dumb things.
The Florida inferno abated, and with temps in the 70's I decided it was time to check the belts. Yeah, I changed them all three years ago when I first received the HMMWV, but two looked warn, Since I had matched replacements in hand, and nothing to do today, I figured I would change them all.
Six hours later, I finished!
Not proud, but I did not remember the easy way I found to do it last time, so I had to figure it out again. Now I know. And this time I am going to write it down!
I have a replacement pump on order.If you pull a pump out…replace it, there is nothing gain by reinstalling an old injection pump, working or not, Murphy lives in all trucks, the seals you can’t get to like the front shaft seal also fail and will leak from the weep hole, the advance plunger is easy but the plungers rust.
NavistarView attachment 941085
Cleared the valley of all residual diesel. Cleared drain. Wire wheeled, Ospho treatment and paint.
Sad we can't get them like thatNew additions to the DRMO yard.
Uh, you know they don't have keys right?Sad we can't get them like that![]()
Indeed. Very accurate to my needs as i have 40's and my original speed reads 4 miles below the actual speed.LOL! You installed the same china speedometer as i
Which model do you have?Indeed. Very accurate to my needs as i have 40's and my original speed reads 4 miles below the actual speed.
M1123 wirh 6.5 turbo engine.Which model do you have?
I asked about speedometerM1123 wirh 6.5 turbo engine.
