Huge mistake. I won a GP auction…. Cali FMTV
GeneralDisorder
5,498
Portland, OR
Hope the transfer case isn’t damaged…
Yeah hopefully the damage was from a forklift not an actual impact. That's a LOT of force required to move the axle like that relative to the springs / frame.
I can't even envision, mechanically, how that shock came to look like it does.
TOBASH
3,686
Brooklyn, NY
I’ve been remaining quiet because I have not yet received the vehicle. I’m unable to comment on any of this damage, and it would be unfair for me to make statements in ignorance. You may absolutely be correct or not.
I will let you guys know when I am able.
TOBASH
3,686
Brooklyn, NY
My vehicle transporter (Daniel who does awesome work in California) told me that the bent shock seems to be forklift damage. Same with the bent driveshaft.
i’m told that the axle alignment looks appropriate and the axle does not appear damaged
I’m told the rig looks relatively new and unused.
I’m told tires hold air AND brakes were able to be disengaged with air pressure and did not need to be “caged”.
I’m told the rig pulled straight when loaded onto the trailer.
More details to follow when I receive her and inspect her.
20,248
Good Deal! Now to find a reputable drive shaft repair shop...
Happy to hear that the air system seems to be intact.
TOBASH
3,686
Brooklyn, NY
Oh hell, this is how it begins… All giddy optimism untill it arrives in your driveway then the reality of “OMG, What Have I Done” sets in…
You do have a therapist on retainer right?
Don’t turn to Alcohol, that path leads to the dark side…:)
Turn to Alcohol? Diesel engines run better on other stuff like Kerosene.
Drinking alcohol is much better and lightens things up.
This will be a learning process. Swear jars will be filled to the brim.
No expectations, just gonna start work.
