Ronmar
- 7,946
- Port angeles wa
Hope the transfer case isn’t damaged…
Yeah hopefully the damage was from a forklift not an actual impact. That's a LOT of force required to move the axle like that relative to the springs / frame.Hope the transfer case isn’t damaged…
I’ve been remaining quiet because I have not yet received the vehicle. I’m unable to comment on any of this damage, and it would be unfair for me to make statements in ignorance. You may absolutely be correct or not.Yeah hopefully the damage was from a forklift not an actual impact. That's a LOT of force required to move the axle like that relative to the springs / frame.
I can't even envision, mechanically, how that shock came to look like it does.
Build a gun truck!.
Yes Sir!
Gotta branch out...
The disease is pretty aggressive.
Next you will want a wrecker to haul your vehicles around.
Or maybe an armored vehicle.
.My vehicle transporter (Daniel who does awesome work in California) told me that the bent shock seems to be forklift damage. Same with the bent driveshaft.
I’m told the rig looks relatively new and unused.
I’m told tires hold air AND brakes were able to be disengaged with air pressure and did not need to be “caged”.
I’m told the rig pulled straight when loaded onto the trailer.
More details to follow when I receive her and inspect her.
Turn to Alcohol? Diesel engines run better on other stuff like Kerosene.Oh hell, this is how it begins… All giddy optimism untill it arrives in your driveway then the reality of “OMG, What Have I Done” sets in…
You do have a therapist on retainer right?
Don’t turn to Alcohol, that path leads to the dark side…![]()
If I had to start over with mine from the beginning, with what I know now, I'd head dive into replacing every flexible line on spec (fuel, coolant, oil, trans), replace every ground connection, swap in a reman oil pump and bypass filter, immediately convert to 24v only alt & 2 batteries while tossing the lbcd and relay, and redo every axle hub seal/bearing service. That's before I started it. IMHOSo… ideas on where to start?
I’m thinking getting the rig to turn over.
What do I need to worry about with the IP?
Common no-start issues after J-6 fuel fudges everything up?
I’ll check the fluids first and then remove the rear driveshaft. I’m told the tires still hold air so I will blow off the CTIS and air pump rebuild for now. I have tools to cage the brakes and inspect and re-grease the air brakes. All this means Richard unless I can get the Diesel to turn over.
Great video for me (the current newbie) to learn from.Here is how you fix the most common issue with the primer/primary filter that causes it to not lift fuel.
my videos are for the 3116, but the primary fuel system between the 3 engines is basically the same. tank, primer/filter, lift pump, main fuel filter, head fuel gallery, pressure regulator and return to tank. Primary fuel pressure(measured between lift pump and main filter) is an often overlooked but pretty important part of the process on all these engines. I have a few other fuel system videos(among other truck vids) under that user name.Great video for me (the current newbie) to learn from.
MANY THANKS!
