well I got a second wind and decided to move further ahead with the fueling mods. I also did a tune up, filters and belts and took pics of the correct part #'s to save you the time at your parts store trying to measure and read through books for an hour. I also Included a pic of me freezing my a$$ off at 11pm getting these photo's to share with the community. The item to the rear of the pump that I am pointing at is where the "fuel button" , "Governor Spring", and "idle adjustment" are located. I added shims between the gov. spring and the spring retainer, each shim added is roughly 30 rpm gained, I added 5 shims. *****WARNING***** When you remove the snap ring for the spring retainer it is under pressure, if you did not know this like I did not and quickly removed the snap ring you will have a yard sale of parts all over your driveway in the middle of the night with only a led headlamp to assist you in finding a spring retainer and 3 original paper thin shims.
The second Item I am pointing at is the aneroid adjustment which dictates how much the truck will fuel pre boost. There is a tin cover on the pumps that covers this up with some creative cutting and brute force I removed the tin cover completely on mine for ease of adjustment.
One last thing, a good practice to get into is marking all of your filters with the date changed and current mileage of the truck, will save you a mess time trying to remember "when the H#LL did I last change that thing"
