Stonepicker1
- 77
- 48
- Coconut Creek, Florida
I was still getting water in my fuel filter and the truck was still running ruff, so I went ahead and droped the fuel tank. It had about 1/2 cup of water total in the tank. I cleaned the sock on the fuel pick-up tube( not that bad, but was dirty ) Put everything back together, added fresh fuel, cleaned and flushed the main filter housing, new filter, bleed all air out of the fuel system and cleared all the codes.
Took for a test ride and the same codes keep coming up. Water must of gotten into the injector pump.
I have a new injector pump that I will install in the morning. I will also be looking at installing another Fuel/Water Seperator before the main filter. This should stop this form being such a pain in the a**.
