srodocker
- 69
- 48
- Lacey, Washington
heres some flexing with a giant forkcliff lifting it up
exactly the rear suspension is what makes these trucks so awsome offroad....To see what they can do even in stock form is mind blowinglooks like more travel than my long armed jeep tj.
the badlands doesnt allow anthing bigger the a blazer.. it is made for jeeps and they frown on people knocking down trees and making thier own trails.haspin has pretty much any kind of terrain you could ever want.850 acres of trails ,two moto cross tracks,side by side dirt drag track.rock crawling hills and mud holes to eat 54s like the are mini spares.. but the cool thing is you can get around almost anywhere there with a stock 4x4 truck or you can take the trail right next to it and get anything stuckThanks, never been there. Do you guys ever take the deuces to the Badlands? I know the trails are a bit tight, but the terrain is pretty good.
Hey Scott, if by any chance you ever forklift your truck like that again, I'd love to know how far their of the back axles is able to drop away from the frame. Want to design some shockmounts for mah deuce, but it's not drivable.heres some flexing with a giant forkcliff lifting it up
I don't know if my rears ever hit. I know I was worried about it when I first put the 395s on, so I made sure they would only hit flat steel and not snag on bracing/jagged edges.Chris are you missing some bump stops in the back.. i have never had my rears hit...Maybe it's cuz my bed flexs up off the frame when i get things twisty?
Thanks for the great detailed information and step by step process. This really helps.Talked with a local 4x4 big tire guru yesterday and he confirmed that about 1/4 inch toe in was what was needed.
So this morning I went out and began the process. First I referenced the TM (9-2320-209-20-3-2 chapter 15) on adjusting toe. Then I went out and loosened the two bolts and clamps holding the rod. I jacked up the front end. I then put a staple in each tire in front and measured the height to the ground and made sure each staple was the same height. Then I attached a tape measure to one staple and pulled it across to the other staple to get a measurement. I then rotated the rod about 1/4 turn and went to check my measurement again. The dimension got larger so I needed to turn the rod the opposite direction. I then turned it about 1/2 turn the other direction and measured again, the dimension got smaller, great. Did about another 1/4 turn and measured and now the dimension was 1/4 inch closer together between the two staples ! Great !
I tightened up the two bolts and lowered the truck down.
My test drive was great, 90% of the "loose feeling" is gone ! I won't toe in anymore since the expert I talked with suggested that if that works to leave it alone. Who would of thought that such a small adjustment could have such a large impact on stability.
I'm very glad I did this. It took me about 1.5 hours since my rod bolts and clamps where rusted and tight. I had to knock the clamps off the bar a little to get the rod to move. It took a giant pair of channel locks to get the bar to rotate. Why didn't they put a square fiting on the rod somewhere ? Oh well, its done !
It is manual steering. Steers somewhat easier than with the stock NDT tires, even with the reduced pressure.Is your truck standard manual steering or is it equipped with the air assisted steering
upgrade?
I also have the manual stock steering and its slightly easier as well. I run my tires at 60psi and will probably drop them another 5-10psi and see if it rides better.Is your truck standard manual steering or is it equipped with the air assisted steering
upgrade?
