M1078A1 "Pandora" Build | 2024-??? | ***Picture Heavy***
Aviator4x4
262
NC
While I'm waiting on parts from Allison, I figured I would tackle the corner bolt issue which was so, so much worse than I thought it was haha. When I removed this shorter, yellow zinc coated bolt... A section of aluminum threads came out with it.
As seen here, with an original transmission bolt which is ~5-10mm longer. Some eagle eyed members might also notice another issue...
The bolt in the trans that ripped the threads out is actually an SAE bolt cranked in to an M10x1.5 hole.
In addition to some higher up threads being broken, the lower threads were all buggered up:
After some internet research, I bought this M10x1.5 Helicoil kit, the shortest 13/32 bit I could find, and the shortest 90* adapter I could find. The 90* adapter was for "impact" but there wasn't much slop so I figured I'd give it a try. Ended up working.
The tap and installation tool were too long so I 3d printed some softjaws, cut them down, and squared the ends to fit snugly in a ratcheting box wrench:
I haven't used too many helicoils before, but seemed to go more or less according to plan. Trying to figure out the best plan for helping those gouges and scrape marks seal... he worst ones are perhaps 1/32" deep or less than 1mm. I think there are two of them, from where someone pried on the aluminum trans block to separate rather than using the jacking ports. Thinking of adding a small amount of RTV on both sides of a new gasket from Allison. Thoughts ? Other recommendations ?
aw113sgte
1,308
La Crosse, WI
Damn, sorry you had an idiot shove the wrong thing in the wrong hole. Nice work on the fix though!
I would use a little rtv, very little. A little loose piece of rtv can cause all sorts of issues in a trans with all the moving control bits.
Aviator4x4
262
NC
Haha yeah... the seemingly endless rabbit hole of transmission problems with this truck strikes again. Discouraging but I just keep holding on to the vision of what I want to build the truck in to. Hopefully I can achieve it with a lot of luck, little bit of skill, and no experience :LOL:
I'm thinking of wetting a fine diamond hone and using that on the gouges to make them flush with the surface, and then putting ~1/16" bead of ultra grey on the trans block gouges. Wait 24+hrs before filling the trans, for sure. After disassembling the entire valve body/control valves, it's not terrible... but I'd also like to not do it again.
Aviator4x4
262
NC
Feeling better about my hypothesis of where the water came from. It rained here yesterday and I could see a waterline/drop on this dry rotted filler seal:
Really hope that is the cause. I can't see any other plausible points of ingress; the breather cap on the top of the trans is in good shape, but I'm going to 3d print a little umbrella for it anyway.
GeneralDisorder
5,771
Portland, OR
You can use JB weld to fill the gouges and sand them down. I've even done that on head gasket fire ring mating surfaces on engines. Customer was fully aware of the risk and "only" wanted another year out of it. That was about 7 years ago and it's still running.
Aviator4x4
262
NC
Interesting idea. I think I might !
Did you use regular JB weld Cold weld or something more exotic ?
Aviator4x4
262
NC
Got the new composite thrustwasher installed, reinstalled the C6 clutchpack in the housing, lined up the snap ring to satisfy my OCD, and got the housing re-installed with 19 new bolts and 1 re-used torqued to 45-55ft-lb.
It went surprisingly smooth considering it's basically a 55# overhead press underneath the truck to get the housing back on.
I made sure to thoroughly coat everything in oil as I was re-assembling, which was awesome when it all came dribbling out of the housing when I reinstalled. Oh well. haha.
Aviator4x4
262
NC
Sidequest: Several friends have pitched in to help work on the truck, or been especially helpful (Allison dealer, for one) so I made this little plastic token as a Thank You. It's double sided with the Aviator4x4 logo on the other side. Plan is to update the design as the truck gets painted or gets the habitat put on.
With how much this build is costing, I might need to have a bake sale that includes one with each cupcake though :LOL: :LOL: :LOL:
Aviator4x4
262
NC
This past weekend I got the valve body/pan back on the truck (what a freaking exercise in tedium that is !) and did my best to flush out all the water contaminated fluid. I pulled the return from the cooler and let that pump ~7gal of fluid into 2x buckets before the fluid turned a more normal oil color. I ended up 3D printing a funnel that fit exactly in the filler hole to make my life 5% easier, but still was a lot of fluids to add !
Before adding any fluid, just letting it drain and getting it pointed towards the bucket.
Aviator4x4
262
NC
I ended up having to idle the truck with my airlines open/venting after the manual hydraulic conversion... I traced the lines; the smaller 1/4" line for cab air suspension goes to the wet tank on the side, but the bigger 3/8" air line for the (now removed) Air/Hydraulic Pump Unit goes to the rear brake anti-compounding valve on my 2002 A1 (A0.5) ... curious difference from the A0, although would make sense if that port was only active when parking brake was on/parking air was removed.
I'm going to try and to get a better picture of what it was attached to. It says "Special" on the band. Perhaps a one way check valve ?
There is another 90* compression fitting on the bottom of "Special" (circled in green, AHPU Air in red)
I was hoping it would be as easy as @Ronmar makes it to be in his AOP air supply control valve removal YouTube video but... of course not :LOL:
Going to be difficult to securely get a wrench the 90* fitting to put a pipe plug in with the rats nest of airlines...
Ronmar
7,918
Port angeles wa
Yea they did it different on the later trucks. From some other pics I have seen i think it is the same type remote control valve as I removed in my A0 video. i think they put it back there for simplicity as primary and secondary tank air are already combined back there with a 2way check valve(near drivers frame rail) to feed the anti-compound valve. so all they had to do to provide AOP air was T off of that line to feed the remote valve that is controlled by park air…
you will have to follow the source line to where it T’s and remove that T. Then trace the park air control line back to where it T’s off of the line feeding the anti-compound . that park air line may also run to the air brake protection valve out on the passenger side of that crossmember(black plastic valve body seen in your pics) that feeds the rear glad-hands. Then of course remove the remote control valve and the line up to the AOP… or you can simply cap that line that runs to the AOP…
