DOGWOODRIDGE
- 3
- 8
- jackson, la
Generator fuel pump question
What is little square box that runs in line with my fuel pump for? Will my new one without that perform properly?Generator fuel pump question
Just quit working. Took cover off. Filter was clean. Put power to it and nothing happens. No clicking. Thank you for your help. Sorry, I’ll be 80 next year and have a little trying to post and send pictures and just about everything in my life. I appreciate your patience with me.
New one is 24V with 8PSIJust quit working. Took cover off. Filter was clean. Put power to it and nothing happens. No clicking. Thank you for your help. Sorry, I’ll be 80 next year and have a little trying to post and send pictures and just about everything in my life. I appreciate your patience with me.
Thank you. I will try that. I do also have an MEP-003 generator. It would be nice to have a spare.Something to try on your old pump... cut out the old RFI suppressor module and butt splice the wires together and see if it works. If it does, you now have a spare. In civilian life you really don't need RFI suppression unless perhaps your a Ham Radio operator or have other sensitive equipment susceptible to RF interference.
The RFI module is notorious for failing at some point and you get the symptoms you experienced, dead pump. Otherwise, you can disassemble the pump internals and clean them up and that might fix it as well. If you do a search in this forum on either MEP-002 or MEP-003 fuel pump you will get lots of information and pictures.
I also have a 3K Yanmar diesel conversionThank you. I will try that. I do also have an MEP-003 generator. It would be nice to have a spare.
Do you have any TM's or information on that set?I also have a 3K Yanmar diesel conversion
I’m sorry. I’m 78 and don’t know what a TM is. I downloaded the manual from Green Mountin if that’s what you mean. Has 3 hours on it.Do you have any TM's or information on that set?
You are very kind. Thank you.You need to stop saying sorry. Nothing wrong with not knowing something, and we are all still learning, up till the dude with the scythe knocks on the door. You got 12 years on me. We may be old, but we ain't dead.
A TM is a Technical Manual. The TM's are the what everyone needs to get smart about equipment. There is more then one TM for this gen set. G.M. tends to not have the latest changed TM's. The TM forum here in SS, Steel Soldiers is, on the whole a bit better.
When you need help, say something. That's what this forum is all about. The first two TM's are the engine TM's. The -24 TM is engine info, and maintenance info. The -24P is the parts info for the engine. The third TM is for the control box and main generator parts. The forth TM is for the conversion from gas engine to Diesel engine. Sometimes its mighty handy. The fifth TM is for the control panel and main generator, operator and maintenance info.
Can you give me the pdf lists like this for my MEP-002 and MEP-003 please.You need to stop saying sorry. Nothing wrong with not knowing something, and we are all still learning, up till the dude with the scythe knocks on the door. You got 12 years on me. We may be old, but we ain't dead.
They can be found here https://www.steelsoldiers.com/forums/generator-and-electrical-tms.121/Can you give me the pdf lists like this for my MEP-002 and MEP-003 please.
