Eastern Front
- 9
- 3
- Mobile AL
Forgot to mention, many of these come with a fuel bowl with a water sensor,, so you can head off a problem with bad fuel before it can get bad...
Was done a year ago.If you haven't done it yet, it may be time to do the dual fuel mod with new fuel line routing.
When determining what to do if I do a turbo, I researched the air to air inter coolers and the water to air units. It is good to visualize that the compressed air leaving the turbo is going to be 250-400 degrees typically. The water to air in my opinion has the best advantages due to the efficiency of the exchange and the significantly smaller size needed to obtain the same results when at normal operating temperature and getting the engine up to temperature if you are in a cooler climate via the heated air bringing the water temp up to the thermostat set-point. These seemed like a win win.I still don't understand why you would use the heater core, running compressed air over 180 degree coolant doesn't seem like an effective way to cool air.
Truck is looking awesome. Can't wait to see how this modification turns out for you! I'm thinking your going to be very pleased.
