Maddogg2.0
- 0
- 0
- Riverisde, Ca
What's ballpark for his injector service?
Yes!Will the position of the switches have an effect on the reading on the voltage gauge, ie 120 volt or 240 or is the voltage reading representing the max voltage the genny is producing.
The arrowThanks for the info btw I was scratching my head as to whether it was the flat part od the d part which represented position
Cummins (engine manufacturer) makes a fantastic injector cleaner. It is pricey, but well worth it. You should be able to get it from any truck supply parts house.What type of injector cleaner would you recommend to run? I have some atf in there which I have had good luck with before
Did you ever hook up again the courtesy outlet?I would also check the valve adjustment and engine timing as soon as I could. TM's explain the procedures. Not as hard as it first sounds when you read it. You asked about the courtesy outlet being disconnected-I had two 002's with the courtesy outlet also disconnected. Never found out why.
You are on the right path.
David
Yep, found wires taped off inside the power box.Did you ever hook up again the courtesy outlet?
