Scratch that... found some info... Field Service Manual (TM 9-2320-361-24-2), Volume 2, Chapter 3, Work Packets 034200 to 034900.
Also (from other forum members!):
- inspect the PTO visually from underneath (severe leaks? loose stuff?)
- inspect the winch driveshaft, including aluminum shear pin (or is it a steel bolt that soldier A left in there??)
- grease the grease zerks on PTO shaft (2 of them).
- with engine off, PTO disengaged, drum lock off, winch clutch lever OUT and winch hook and chain unhooked, pull on the winch cable. Does the drum spin and can you unwind a few yards of cable?.
- with engine off, PTO disengaged, drum lock off, winch clutch lever IN and winch hook and chain unhooked, turn driveshaft by hand .
Does it turn both ways? Does the winch drum spin? If there is no way you can turn it, disengage the winch clutch. If you can turn the shaft now, you could have an issue with the band brake. If you still cannot turn the shaft, ensure everything is really disengaged; you could have an issue with the winch drive (worm gear).
- check oil presence and level in the winch housing. If there is none, add something thick....pure Lucas oil additive, for example. Many use cornhead grease (oil that behaves like grease; from JohnDeere). Mil Spec fluid is 90W GL1. Spec capacity is 1.5 pints on Drivers side, 0.75 pints on Passenger side. Likely, your winch seals are leaking (common).
With this inspection satisfactory, you could be more confident powering up the winch as per the TM.
I think the most important advice is that the winch is operated from the cab - not by playing with the drum clutch up front.
