- 2,136
- 616
- 113
- Davis County, UT
I now have troop seat bench pads, and they are still military surplus and a pretty dang good fit and the perfect color! I will need to make tie down straps, but that should be easy with some buckles and 1" nylon straps.
Dimensions: 74.5" long x 13" deep x 1" thick
I purchased them from my all-time favorite surplus store that I have been going to since I was a child. I still always visit in person when I'm in the area.
http://www.armysurpluswarehouse.com/us-gi-issue-seat-cushion.html
Apologies, it's a bit dark in the bed and pictures always suffer for it.
Edit:
The backside loops (there are 3 pairs), fit 1" nylon webbing perfectly.
- So they're a little long (2 * 74.5 = 149") as the troop seats are only about 143" long, or 6" excess seat pad material. Unless I decide to bother shortening 2 of the pads, I will just tuck the excess at the front of the bed.
- The depth is almost perfect as the troop seat bottom is about 13-3/4" deep, and you really can't even sit on the very back of the seat anyway.
- Even though they're only 1" thick, the pad is firm and doesn't compress to nothingness.
- Web page description:
- SEAT CUSHION FSN # 2510-01-109-5028 2600308 * U.S. GOVERNMENT ISSUE * WIDTH 13 INCHES * LENGTH 74.5 INCHES * THICKNESS 1 INCH * COVER MATERIAL - NYLON MIL-C-20696, TYPE 2, CLASS 3 * PADDING MATERIAL - PLASTIC, MK-P-15280 * COLOR - OLIVE DRAB * NEW THIS SEAT CUSHION IS ORIGINALLY MADE FOR THE ASSAULT AMPHIBIOUS VEHICLE - COMMAND OR PERSONNEL. IT WOULD BE A GREAT CUSHION TO USE ON A BENCH OR PICNIC TABLE OR WHEREVER YOU WANT SOME ADDED COMFORT. IF YOU HAVE A MILITARY VEHICLE THIS MIGHT BE AN EXCELLENT CUSHION FOR YOUR BENCHES IN THE BACK. THIS HAS 6 TIE DOWN SPOTS ON THE BACK OF THE CUSHION.
Edit:
