What have you done to your JEEP today
Gunny 0369
Marine Gunnery Sergeant
637
North Carolina
LoL. Not sure I’m going to sink it in mud after the restoration that I have planned. But I already like this one more than a Wrangler that I had some years ago. @Another Ahab … Too many but my wife is understanding and forgiving.
View attachment 929364View attachment 929364
The ideal all-purpose farm vehicle!
Do you maybe work that M38 regularly out there?
I use mine like a side by side, and to town often.
Dont keep them in the garage and rub them with a diaper, you cannot take it with you when you die!
(And it looks more authentic with mud caked all over it)
sigo
Lieutenant Colonel
389
Leavenworth, KS
Flat fender Jeeps are the original side by side!
I don’t really work it hard, but do I use it like a side by side sometimes. Hauling tools to where I’m working, I’ve used the winch to tension trees I’m cutting down, towed other vehicles or trailers. Really only light duty stuff. I’m sitting in it right now after looking around the field for a large rock I want dig up. I have a Kubota tractor to use for the hard work.
JEB
136
Colbert, WA
Not much new to report since I was rained out of taking it to the Air National Guard's centennial event a couple of weeks back.
It was the first rain in weeks....figures.
Today, as usual, took it to Sunday breakfast at the local fast food joint.
I have taken all of my old cars there, most are much fancier, more expensive and rarer than the M38A1...but none have received more positive comments.
Some are from vets, one was a woman who said said her late husband was an Air Force retiree, others are just Jeep fans.
I even was left a second rubber duck a few weeks back.
So, get out and drive them before winter.
DeetFreek
351
New Sharon IA
Sounds like my interactions as well JEB. I've been in the classic car thing for longer than I can remember and in the few short years I've had my A1, I've had so many more interactions than all of my other rides combined. Wouldn't trade them for anything either. From talks with vets to letting kids sit in and climb around it, there's a smile on my face that's irreplaceable.
HoveringHMMWV
1,031
AL
Spent the last 5 weeks evaluating the new to me non-running M38 and making repairs. My goal was to get it running, configured as close to TM as possible, before beginning a restoration. Removed and replaced the dual action fuel pump that had failed and was leaking fuel into the engine. Previous owner(s) didn't have any of the vacuum/fording lines installed or were installed incorrectly. Replaced all breather, coolant, and oil hoses/lines. Oils were very dark and looked to have not been changed for years. Installed a new 160 F thermostat and retainer as they were completely missing. Changed all fluids (engine oil, breather, trans, t-case, diffs, and coolant) and greased the chassis as per lube order. Runs ok now with temp maxing out around 190-200 F. Shifts smoothly with all gears normal. First jeep with L134, so getting use to the performance. Will climb moderately steep hills in first gear but boggs down in 2nd or 3rd. Will have one of the club members test drive it and give their opinion.
I believe that I have most of the vacuum/vent system hooked up as per the TM. But the jeep seems to idle much better with the fording valve partially to fully closed (image shows valve fully open). Question: Could my PCV valve be installed backwards to cause this or is this a symptom of too much blow by?
A civilian oil filter canister and possibly an earlier MB or GPW breather were installed at some point in it's history. I was not sure of the purpose for the red circled port on the breather can. I just capped it off while I search for the correct breather.
Another Ahab
4,449
Alexandria, VA
Great loooking machine all around, HoveringHMMWV.
Hoses. The rubber. Even the canvas looks good.
Nice!!
