Valor
202
Apple Valley, Ca.
Using the common body ground, the new one has no reading at any setting. At the 2M setting on my multimeter my ohm reading on the old solenoid is all over the place on either pin or the body.
Check the windings with ah ohm meter with one probe grounded to the solenoid body, separate from the truck ground. You want to see if there might be a short in the windings. There should be infinite ohms, no continuity. If there is some, that means there is a short and pulling down the voltage to operate the solenoid.
Wreckclues
544
Jefferson, Massachusetts
I gutted the old fuel shutoff solenoid on my M813 to turn it into a full manual valve and now the engine won't start.
Figure I've lost prime in the lift pump as this is the first time I've had the shutoff valve side of the fuel circuit disconnected. When I had the supply side off for troubleshooting filters, lines and the pickup tube all I had to do was use a transfer pump to pull fuel through the filter then screw the supply line back into the lift pump and she'd start within 10 seconds.
The threads I've seen for priming an NHC250 pump show an actual manual pump which my rig doesn't have.
Is there anyway to manually prime the Lift Pump on my M813 to save my starter?
msgjd
3,192
upstate ny
unfortunately that's the nature of the M809-series , losing prime is easy once their system is opened up.. Changing a fuel filter beside the road without having a can of fuel to fill the filter can is impossible unless you have a hose and like the taste diesel fuel , and even then, priming is still a bear.. I have always wanted at the very least to put a check valve on the M809's, or better-yet an electric bypass-type pump just for priming .. Another trick is to have a fuel tank filler cap with an air fitting (and pressure regulator) to force the fuel up out of the tank , and i clamp the rubber part of the return hose with vice grips.. The setup also gives you an excuse to make a carry-along air hose with gladhand for such occasion and for tires .. The ultimate "fix" I have seen on an M809-series is the commercial spin-on fuel filter head having an integral manual priming pump.. Old Caterpillar engines had a similar goodie as well, but in time tended to leak around the primer shaft and suck air
kendelrio
8,587
Alexandria, La
My "whoop whoop" lights (convoy lights) quit working. I checked the breaker on my overhead console it's run through and sure enough it was popped, telling me either I was grounding out somewhere or amping out due to a frozen motor.
I disconnected the lights from the relay and tested and it didn't pop, so my trouble was "downstream" of the power/switch/relay side.
I disconnected them both at the "Y" connector and it didn't pop, plugged them in one at a time and the issue was the right light.
I disassembled the light and checked the motor, it spun freely.
After removing some electrical tape put there by a previous owner, I found the insulation for the power/ground wires was rotten and allowing them to touch, shorting out the circuit.
A little repair later, all is good!
Wreckclues
544
Can the cold start pump on the dash be used to prime the lift pump? One of the 5-ton gang on Facebook thinks it can...time to check the TM's
Damn, forgot the cold start pump draws from the lift pump.
