M1224
- 38
- 18
- Croswell, MI
I have to replace the Pressure Transducer first so the system can read tire pressure again, then I'll start playing with it. Anyone know the PN for the P110 pins?Heck yeah! Let us know what you find!
Since the A0 doesn't have a J1939 bus at all I would *assume* it would work without issue. The only issue with them on the A1 trucks is they burn out the J1939 termination resistors if you don't pull the pins out of them. Not having those pins doesn't affect their operation though - seems that Dana left some pins hot that they assumed wouldn't ever be used and those ended up being the pins they later used for the J1939 so it kinda broke the forward compatibility unless you know to pull the pins out or disconnect the wiring to them.Do the M939 CTIS controllers work without modification in the LMTV A0's? I know the A1 can talk to it, but the A0 can't. Has anyone used one?
As @GeneralDisorder does, I *assume* the M939A2 CTIS ECU will plug and play in the LMTV A0 variants. Easy enough to check. Use the M939A2 CTIS schematic from post#65 and match to your A0 schematic?Do the M939 CTIS controllers work without modification in the LMTV A0's? I know the A1 can talk to it, but the A0 can't. Has anyone used one?
That happened the first time I powered up my system too! I did manage to get it to stop fortunately so I could drive home from @Lostchain 's shop. PCU spool valves were contaminated with crap from the wet tank. They really should have given the PCU an inline filter so crud from the wet tank wouldn't get into it.Well, looks like I have a lot more work. I used the jumper wire method to check for leaks, and as soon as I jumped pin B to open the wheel valves, the tires started deflating out the dump valve. Time to pull the PCU and go through it. I did get Pin M switched to Z, so I'll have 81 psi highway when it's back together. then I can work on the switches.
That's probably the main issue then. When powered, it reads 00.00 Volts. Test failed, 5 flashing lights.Well yes there is something for it to read, with control open the manifold that the sensor is connected to is open to the atmosphere. Thats its first check, can it see atmospheric pressure… If it cannot see that it will not proceed…
Not yet. Doing that today.have you had the PCU sensor out?
The slight angle they put it at was a sorry attempt to compensate, but was never enough to do any good.They installed it pointing straight up, which is usually considered poor form for sensor installation because they can collect crap…
Once I start updating the configuration, adding in the AC and audio (and an interior light), I'll start tackling the manual CTIS conversion.Don't have these issues using 2 switches a relay and a pressure gauge. At this point in my life I think I can live without a black(or green) box checking my tire pressure every 15 minutes...
It would be the proper course of action to simply ask the controller you have what is wrong with the system, and then repair from there. Dana Diagnostic Tool and a J1939 adaptor is what’s required for this.I have a feeling it's time to collect about a dozen green boxes and just keep trying them out till I find one that works.
Except the J1708 and J1939 are not pinned in the CTIS harness. My truck has a J1708 Diagnostic plug, but only the Trans is connected.It would be the proper course of action to simply ask the controller you have what is wrong with the system, and then repair from there. Dana Diagnostic Tool and a J1939 adaptor is what’s required for this.
Might be more work than you want to do but the pins are present in the controller, and if you already have a J1708 port for the transmission, might make sense to just run the CTIS 1708 over there so you have access to both controllers. The DDT is just the right tool for the job on CTIS. It works just as good (only slightly slower) on the low speed bus.Except the J1708 and J1939 are not pinned in the CTIS harness. My truck has a J1708 Diagnostic plug, but only the Trans is connected.
Yeah, what Ron said... LOVE my two switch system. No regrets and completely reversable.Don't have these issues using 2 switches a relay and a pressure gauge. At this point in my life I think I can live without a black(or green) box checking my tire pressure every 15 minutes...
Only problem is, with the dump valves open, I don't have a compressor strong enough to keep up and hold that much pressure in the lines.disconnecting the PCU output line and connecting a regulated air source to that line at say 55-60PSI to hold the system at pressure is the best way to track CTIS leakage.
They shouldn't open with a regulated supply at 55 psi going into their control line and if they are venting they would be venting *tire* air not air from your compressor. That should inflate the tires (if they are low) to that pressure and stop - if they are higher than 55 the air from all the tires will mix and equalize...... The QRV's just replicate to the wheels whatever pressure is sent to them. If one is open and the tires are still deflating on that axle then there's some kind of partial blockage keeping the pressure between the valve and the tires artificially low or a leak before the valve that is artificially dropping the pressure on the QRV control port.......Only problem is, with the dump valves open, I don't have a compressor strong enough to keep up and hold that much pressure in the lines.
Good god is it ever. I can't wait to get it all fixed...yes it's quite the mind game wrapping your head around how they function isn't it?
That's my project for this weekend.Hand over hand the lines and find/fix your major leaks, then break out the bubble mix to find and fix the little ones
