Attached pics of the two 13mm bots and one 15mm nut that I removed.
Ah! Let me go check.There are three fasteners holding the pump to the block, just like cucvrus said. They are 120 degrees from one another. One on the top and two on the bottom. One on the drivers side, one on the passenger side.
That heavy rubber connection only served during assembly so the hoses were put on the correct side. It it leaks you can eliminate it and put the hoses directly onto the vacuum switch.
Fuel feed removed. Correct the pump is ready to go. I had the easy part you did the work. CUCVLOVER painted his intake OD green because he leaves his hoo up all the time when he is looking at his engine He did not want it to break up the camo pattern from an aerial view. I will be available when the pump returns. Unless my name gets roll called up yonder.Hopefully I haven't screwed something up! I got off at 5pm and went straight to work on the truck. CUCVRUS, thank you for the guidance! I hope you're available when the pump gets back! I'm thinking I might paint valve covers in the meantime. I'm not certain, but I think valve covers are straight forward, and should come off easily, right?I'm debating between Detroit Diesel Alpine green engine enamel or stick with black. The next couple of weeks, while waiting for the pump, I'm hoping to be cleaning and painting some. [edit] Checking pics of injection pumps on the big auction website and they show pics with the intake fuel line removed. So, I've pulled this part since taking the pics.
That is basically it CUCVRUS.Fuel feed removed. Correct the pump is ready to go. I had the easy part you did the work. CUCVLOVER painted his intake OD green because he leaves his hoo up all the time when he is looking at his engine He did not want it to break up the camo pattern from an aerial view. I will be available when the pump returns. Unless my name gets roll called up yonder.
