watkinssr
- 3
- 0
- Fort Worth, Texa
lol
No, i put on a new filter. My thought was that maybe the base was leaking, but it doesn't appear to be the case. I think it actually was the fuel lines going to it. One of them had a splice in the middle. Tomorrow I'm going to hook it all back up again, with brand new fuel line, and see if I can get somewhere with it.Was the fuel filter clogged?
As I mentioned on page 5 of this thread that was exactly what was causing my M38a1 to do what your truck is doing. It is really difficult some times to find a fuel line with a splice in it. I hope that was the issue so you can get it on the road.. I think it actually was the fuel lines going to it. One of them had a splice in the middle. Tomorrow I'm going to hook it all back up again, with brand new fuel line, and see if I can get somewhere with it.
Yeah, this was down behind the intake at the back.As I mentioned on page 5 of this thread that was exactly what was causing my M38a1 to do what your truck is doing. It is really difficult some times to find a fuel line with a splice in it. I hope that was the issue so you can get it on the road.
O yea...if you guys want an example of how crappy a spliced fuel line is take a soda straw and cut a small line length wise into the straw and try drinking with it...it works but it "sucks"...lol
Yeah, I checked that, it's lined right up. I'm thinking either we're still getting air into it, or the IP is shot. Which is wierd, cuz the IP, like everything else on this truck, looks new.I feel your pain, I spent about 30 mins on my M1009 today in this heat, wow it was like 98 outside in Fort Worth. I removed and checked all of my glow plugs and they were all good, just rusty contact points, so I cleaned them. Afer that I was done, too hot outside and really the only project I needed to do.
Is the IP aligned correctly to the engine block?
There is a mark on the Injector Pump base and the engine block, you may have to clean the area to see them. These should be aligned with each other, if not loosen the blots and line them up. See if that fixes your issue. I do not recall if I looked at that when I saw it at the lot, but my M1010 has this issue and was not aligned.
