- 5,586
- 2,866
- Metairie/La (N'awlins)
Matched belts can be found with Gates or Napa. They typically will have a red tape around the set. Usually you have to go to a very large store or for NAPA at a distribution warehouse store main counter.
The way to tell a matched set is they are cut from the same cord or production. To verify this, check the digits/code after the part number like nbb12 or something like that. Then there is usually a number to tell you which piece it was off the cord like 12 or 13 etc.. Matching numbers are nice but as long as the cord production is the same, they will stretch and work as a "matched set"
